Create C# Model From TSQL Table
The attached zip file contains a TSQL stored procedure that can be used to create a C# Model for a given TSQL table.
usage: EXEC [dbo].[sp_ModelFromTable] tblExample
Running that stored procedure will produced the model shown below:
using System;
using System.ComponentModel.DataAnnotations;
using System.ComponentModel.DataAnnotations.Schema;
namespace Database.Model
    [Table("tblExample", Schema = "dbo")]
    public class tblExampleModel
        [Key, DatabaseGenerated(DatabaseGeneratedOption.Identity)]
        Column("ID")]
        public int ID { get; set; }
        Column("Name")]
        public string Name { get; set; }
sp_ModelFromTable.zip
(1.92 KiB) Downloaded 2729 times
