MS Win32 Programmer's Reference
Here you will find links to HtmlHelp and WinHelp files that will work with the Zeus QuickHelp feature.
Locked
The Microsoft Win32 Programmer's Reference in CHM Format can be downloaded from here: http://laurencejackson.com/win32/index.html
This help file is an excellent source of documentation for many aspects of the Win32 API.
NOTE: To get the file to load correctly it will need to be unblocked using the option found using the Properties menu:
Once the file is unblocked it works perfectly with the Zeus Quick Help searching feature:
Locked
