As an example consider the test.js file which contains the following code:
foo(reallyLongArg(), omgSoManyParameters(), IShouldRefactorThis(), isThereSeriouslyAnotherOne());Code: Select all
foo(
reallyLongArg(),
To fix this you need to point the npm cache to the short-name version of the user folder as shown below.npm ERR! Could not install from "User Name\AppData\Roaming\npm-cache\_npx\19748" as it does not contain a package.json file.
Find out the short-name of the users folder:
C:\Users>dir /xCode: Select all
npm config set cache "C:\Users\UserName~1\AppData\Roaming\npm-cache" --global[code]
Save the code below to the Zeus [i]zScript[/i] folder using the [i]prettier_fmt.lua[/i] file name and setup the macro as per the instruction found in the comment section of that macro script:
[code]--
-- Name: Prettier Reformatting Macro
-- Language: Lua Macro
-- Description: This macro will execute the Prettier utility to reformat
-- the current file.
-- To run the macro directly use the Macro, Execute menu.
-- To automatically run the macro of any file save action edit the
-- document type and in the Triggers section add the following
-- command to Save and Save As postfix section:
-- $zud\zScript\prettier_fmt.lua
local utils = require "utils"
-- details about the active document
local document, named, read_only = utils.document_details()
if (document == 0) or (named == 0) then
-- only complain if this is not a trigger
if is_trigger() == 0 then
message("This macro only works with named, writable documents.")
-- More command line options found here: https://prettier.io/docs/en/cli.html
-- write file in place with not logging information command line options
local cmd_options = "--write --loglevel silent"
local dir = macro_tag("$fdd")
-- the package file
local package_file = dir .. "package.json"
-- NOTE: Without a package.json file the Prettier formatting request will fail with
-- an error so we check to make sure that file exists and if it is not found
-- change the command line options accordingly.
-- An alternative to this approach would be changing the command line to use
-- a global configuration file option.
if (zeus.access(package_file, 0) ~= 0) then
-- revert to a 'no-config' setup
cmd_options = cmd_options .. " --no-config"
message("Prettier is formatting the code....")
-- build up the final command line
local cmd = "npx --quiet prettier" .. " " .. cmd_options .. " " .. utils.checkLFN(file_name)
-- for debugging only
--message_box(1, cmd, "Zeus Debuggging Only - Command Line")
-- System Control Values
-- 1 - save the document before running the program
-- 2 - capture any standard output generated by the program
-- 4 - capture any standard error generated by the program
-- 8 - ask for additional arguments
-- 16 - the program will use the MS-DOS command interpreter (ie. dir *.* etc)
-- 32 - wait for the program to complete (the ESC key will cancel the wait)
-- 128 - capture output to a compiler window (not the default tool window)
-- Output Control Flags:
-- 0 - ALWAYS
-- 1 - NEVER
-- 2 - ERRORS
-- 3 - WARNINGS
-- 4 - ANYOUTPUT
-- display the tool window if any output is generated
local ANYOUTPUT = 4
-- use 'save', 'capture output', 'capture error', 'MS-DOS', 'wait' and 'compiler' options
local flags = 1+2+4+16+32+128
local caption = "Prettier fmt: " .. file_name
-- remember the current line count
local current_count = get_line_count()
if (system(cmd, dir, flags, caption, ANYOUTPUT) == 0) then
-- reload the newly formatted docuemnt
FileReloadCurrent()
-- get the new line count
local line_change = get_line_count() - current_count
-- maintain the current line location
if line_change ~= 0 then
local line_current = get_line_pos() + line_change
if line_current < 0 then line_current = 1 end
set_line_pos(line_current)
-- no errors detected
set_return_code(1)
-- some feedback
message("The formatting of the document is complete.")
-- formatting errors detected
set_return_code(0)
