bringing Zeus to foreground when a file is opened
Loving this editor. Minor thing. When I open a new file by double clicking in some other APP like Windows explorer or ZTree, the Zeus window remains in the background. Of course it is trivial to click on the Zeus window to bring it to the front. If there is a way to set Zeus to make itself the foreground window automaticallly when a new file was opened I would love to know it. As it stands now, the Zeus icon on the status bar starts flashing but the Zeus window remains in the background. This is very polite and civilized behavior but not what I would prefer the way I tend to work.
Re: bringing Zeus to foreground when a file is opened
I will need to do some investigation into this to see if this can be fixed.
FYI Zeus does already contain lots of 'bring to foreground' code, but over the years Microsoft has change Windows itself to stop that sort of code working.
I think what happened is that some time ago, unscrupulous adware software developers abused this feature by making their adware continuously pop up making Windows almost unusable.
To stop this Microsoft ended up severely limiting the power of that 'bring to foreground' Windows API.
But there are still ways around this so with some luck a fix for this might still be possible.
I can understand how this would become annoying, so hopefully a fix is possible.
Check this space in the next week or two for feedback.
Thanks for taking the time to post your feedback.
As a simple test using Windows 10 and I set up Windows Explorer so that all .cpp files would be opened in Zeus.
I could see the change take effect as all the .cpp files took on the Zeus icon inside Explorer.
However, when I double click on any of these files they always brought Zeus to the foreground.
Do you have simple way to replicate this using Windows explorer
In any case it occurred to me there might already be one possible fix
In the registry I have this setting for the Zeus shell command:
You could try adding in the -f Zeus command line option to that command as follows.
Note: The <userID> in the text above will need to be changed to match your user id. Also make sure that the final string is the actual Zeus installation folder.
That -f option means Zeus will try to force itself to the foreground.
[HKEY_CLASSES_ROOT\Applications\zeus.exe\shell\open\command]
@="\"C:\\Users\\<userID>\\AppData\\Local\\Programs\\Zeus\\zeus.exe\" \"%1\""
@="\"C:\\Users\\<userID>\\AppData\\Local\\Programs\\Zeus\\zeus.exe\" -f \"%1\""
This issue has been replicated on a Windows 7 machine and a possible fix is being worked on.
When a working fix has been found a new beta release will be made available a note will be posted to this thread with a download link to that beta version..
This issue should be fixed in the latest Zeus release found here: https://www.zeusedit.com/download.html
To upgrade to this local version follow the instructions found here: viewtopic.php?f=5&t=2719
