Configuring Code Completetion
emollusc
Post by emollusc »
Hi, I hope somene can help...
When writing C++ code I would like to edit the default behaviour of the code completion. For example when typing
#include
the I get the following
#include ""
where I want
#include <>
or nothing as I am able to type the <> comands quite quickly. As yet I've not found any way to edit this behavior and would appreciate some help.
Brian
Re: Configuring Code Completetion
Hi Brian,
This default C++ code completion is found here:
1. Options, Editor Options, Document Types menu
2. C/C++ Document Type
3. Templates
4. 'Include Headers' Smart Template
All the if, for,while, switch, case etc C/C++templates are define here.
So if you decide you want to make big changes to all these templates I would recommend doing this:
1. Export the current setting using the Backup button
2. Backup that export file just in case
3. Edit the export file and then just do a import which will replace the current templates
Now back to your question.
The behaviour you are seeing is defined by the following template found in that list of templates:
        Keyword: #include
      Menu Text: Include Headers
 Expansion Text: $MacroExecute<includes.lua>
What this all means is as follows:
1. The template is trigger by the #include text
2. The Menu Text is the text displayed in the menu/navigator panel
3. The Expansion Text is what is used to replace the trigger
In this case the expansion text is running the includes.lua macro.
To open that macro file type this text into a new Zeus document:
zScript\includes.lua
Next, place the cursor on that line and use the View, Open File menu to open the file.
In that macro you will see this text in a few places:
-- fire off the default text
output_buffer("#include \"\\c\"")
Change that text to be:
output_buffer("#include <\\c\>")
That will need changes to lines 88, 99, 109 , 113, 117 and 121.
You can naturally configure it to this as well.
FYI the \c in that text represents the final cursor location.
emollusc
Post by emollusc »
thanks for the comprehensive reply,
Brian
