URL Decoding Macro
URL Decoding Macro
Consider the following mapping of characters to their encoded equivalent value:
   %21 %23 %24 %26 %27 %28 %29 %2A %2B %2C %2F %3A %3B %3D %3F %40 %5B %5D
As an example this macro will take this string:
and produce this decoded result:
Here is the macro:
#        Name: Unquote Marked Region of Text
#      Author: Jussi Jumppanen
#    Language: Python
# Description: This macro will unquote a marked region of text and add
# the results to the clipboard.
# Consider the following mapping for characters to their encoded equivalent
# value:
#    %21 %23 %24 %26 %27 %28 %29 %2A %2B %2C %2F %3A %3B %3D %3F %40 %5B %5D
# As an example this macro will take this string:
# and produce this unquoted result:
import zeus
import urllib.parse
def unquoteMarkedText():
    if zeus.is_marked():
        text = zeus.macro_tag("$wex").decode('utf8')
        zeus.set_clipboard_text(urllib.parse.unquote(text))
        zeus.message("The unquoted text has been added to the clipboard.")
    else:
        zeus.message("No text is currently marked.")
        zeus.beep()
unquoteMarkedText()
Last bumped by jussij on Thu Mar 24, 2022 5:40 am.
