Slightly extended bookmarks
Michael
Post by Michael »
I've written some simple scripts for a slightly extended bookmark handling. Using the scripts it's possible to toggle a bookmark for each line and cycle through them. As a side effect of having to use the global string database for storing the bookmarks, the bookmarks will be persistent even after restarting Zeus.
It may not be the most rock solid solution for each and every case but for me it's working well so far.
Save the code using the suggested filenames and map bookmarks_toggle.lua lua to ctrl-f2 and bookmarks_next.lua to f2 to get the commond handling used in most IDEs.
Regards,
Michael
-- file bookmarks.lua
function bookmarks_read( name )
    name = name or "unknown"
    local tb = {}
    local s = get_global_string( name ) or ""
    local numlines = get_line_count()
    for bl in string.gfind( s, "%d+" ) do
        bl = tonumber(bl)
        if bl < numlines then
            table.insert( tb, bl )
    table.sort( tb )
    return tb
function bookmarks_write( name, tab )
    local s = ""
    for idx, bl in pairs(tab) do
        s = s..bl.." "
    set_global_string( name, s )
function bookmarks_next()
    local fname = get_file_name()
    local tab = bookmarks_read( fname )
    local line = get_line_pos()
        if bl > line then
                set_line_pos( bl )
    if tab[1] ~= nil then
        set_line_pos( tab[1] )
function bookmarks_toggle()
    local idxat = nil
        if bl == line then
            idxat = idx
    if idxat ~= nil then
        table.remove( tab, idxat)
        table.insert( tab, line )
        table.sort( tab )
    bookmarks_write( fname, tab )
-- file bookmarks_toggle.lua
dofile( "bookmarks.lua" )
bookmarks_toggle() -- run the macro
-- file bookmarks_next.lua
bookmarks_next() -- run the macro
Hi Michael,
These macros are cool 8)
My only suggestion would be to add a little visual feedback to the macros. For example, I "** added" a small amount of user feedback code to the bookmarks_next and bookmarks_toggle functions found in your bookmarks.lua file:
        if bl > line then
                set_line_pos( bl )
                -- ** added: found bookmark
                message("Moved to bookmark at line ".. bl)
    -- ** added: default message
    local message_text = "No bookmarks found for this file!"
        message_text = "Moved to bookmark at line ".. tab[1]
    -- ** added: display message
    message(message_text)
    local idxat = nil
        if bl == line then
            idxat = idx
        message("Book mark removed from line ".. line)
        table.sort( tab )
        message("Book mark dropped at line ".. line)
