doskey.exe application error in a batch file
johnsea
Post by johnsea »
I do not know if this is a configuration problem or a bug.
I setup my project using project option to run a .bat file that does stuff to compile my project. This .bat file has been used for years on NT, 2000, and XP with no problems.
Everytime I build the project I get this doskey.exe - Application Error dialog box to pop-up. When I click the OK button, another doskey.exe -Application Error dialog box pops up.
The .bat file completes and project completed with no errors. This batch file does call another batch file that does call doskey. Why am I getting this error when I use Zeus for Windows but when I use my current editor Codewright, It works just find? Is this a bug?
I download the latest trial version to check this editor out. I used to use Codewright V7.5 but this editor sometimes hangs-up. Expecially if SoftICE is loaded.
Can you post the contents of thsi batch file to the end of this thread.
The Zeus software protection is provided by the AsProtect product. AsProtect has special anti-debugging detection built in and I suspect it is this might be causing the hang :(
johnsea
Post by johnsea »
Thanks for the reply.
After analyzing the batch file, I realized that the doskey command was not needed.
This batch file was obtained from the Microsoft DDK and was used to setup the environment. I used it to setup the environment and compile my driver. Doskey.exe was not needed.
amix
Post by amix »
I have the same problem.
I have a CMD_Startup.BAT for each CMD.exe invocation where the doskey.exe is being used:
@doskey d=dir $*
@doskey n=notepad $*
@doskey home=cd /d "%USERPROFILE%"
@doskey ..=cd ..\..
@doskey ...=cd ..\..\..
@doskey dot=dopusrt /cmd GO PATH="$*"
@doskey don=dopusrt /cmd GO NEW PATH="$*"
Each of these doskey instances crashes, but the tool, as configured in Zeus, gets executed. When I use the CMD console manually this problem does not appear.
Also of interest may be, that, if I open just a DOS shell (the one preconfigured in Zeus, named xDOS), this problem does not occur either.
