Zeus dialog boxes appearing on wrong monitor
gwgs
Post by gwgs »
My setup, laptop running win10, with 2 monitors, making 3 screens
Zeus main window on monitor 2, laptop screen is monitor 1
When Zeus is maximised on monitor 2, all the dialog boxes appear on that monitor
When Zeus is running as a non-maximised app on monitor 2, some of the dialog boxes will appear on monitor 1.
Specifically the option box, and the jump to line box.
Grant
Re: Zeus dialog boxes appearing on wrong monitor
Hi Grant,
Can you tell me which version of Zeus you are running :?:
Also can you tell me if one of the main culprits is the File Open dialog :?:
Finally, if you wish, you can try this new beta version: http://www.zeusedit.com/z300/zeus-beta.zip
This version has fixed most multi-monitor issues, except for the File Open dialog.
IMPORTANT: If you trying out this newer version make sure you FULLY BACKUP your current version as described here:
viewtopic.php?t=7645
and here:
viewtopic.php?t=2719
gwgs
Post by gwgs »
I was running Zeus 3.98l. I had no issue with open file or save file dialogs
I have installed the beta, and it works good.
Grant
