slietart
Posts: 2 Joined: Thu Oct 12, 2017 3:46 pm
Post
by slietart » Fri Oct 13, 2017 2:44 pm
Hello,
I am currently testing the AgentGit trial version with Powerbuilder 12.6 before purchasing about 40 licenses, but I notice that the refreshStatus is very slow:
I wonder if the log of the very many phrases below is not the cause ? :
[Fri Oct 13 15:53:43 2017] >> *** These addition messages are only displayed if the software is unregistered ***
Extract Log of the refresh duration below :
[Fri Oct 13 16:30:37 2017] >> Cmd: git.exe status -s nv_mail_manager.sru Duration: 0.124 sec
[Fri Oct 13 16:30:37 2017] >> Cmd: git.exe status -s nv_ddac.sru Duration: 0.125 sec
[Fri Oct 13 16:30:40 2017] >> SccQueryInfoEx Duration: 3.12 sec
[Fri Oct 13 16:30:41 2017] >> Cmd: git.exe diff --ignore-all-space --ignore-space-at-eol --ignore-blank-lines HEAD nv_mail_manager.sru Duration: 0.999 sec
[Fri Oct 13 16:30:41 2017] >> SccDiff Duration: 1.108 sec
[Fri Oct 13 16:30:42 2017] >> Cmd: git.exe diff --ignore-all-space --ignore-space-at-eol --ignore-blank-lines HEAD nv_ddac.sru Duration: 0.952 sec
"Git Diff" cmd seems to be long ??
Is that or is it something else?
Thanks for your answer.
Regards Slietart
Posts: 2655 Joined: Fri Aug 13, 2004 5:10 pm
Post
by jussij » Fri Oct 13, 2017 11:06 pm
In your
other post you show an image of the PowerBuilder workspace.
Can you change the PowerBuilder
status refresh rate from
5 to
59 and see if that helps
Agent Git always returns the correct status so this extract polling of the status by PowerBuilder is just a waste.
The times shown in the log are the time it is taking to run the actual Git command.
For example if you did the following:
Copied the Git command and directory details from the log
Went to the Agent Git configuration dialog and hit the Dos Shell button
Changed to the correct directory
Ran the Git command
You should see a similar delay to the one that was recorded in the log file.
