As there is now the highlight all occurrences macro, would it be feasable to have that functionality added to the find /find/replace dialogs as an option? in much the same was as vim does on *nix
Grant
Add highlight all occurrances option to find dialogs
Re: Add highlight all occurrances option to find dialogs
I'm not sure which version add this feature, but it is definitely there in the find dialog in the current version.
I will look to also add it to the replace dialog.
That's it!. Thanks Jussi, I hadn't seen that option previously, just the options i primarily use 'whole word' and 'match case'
In the latest version there is a keyboard function that does this.
For the BriefEx keyboard mapping this is bound to the Ctrl+H (i.e. the H is for highlight) will run this feature.
That keyboard action is bound to the WordHighlightAny keyboard function.
