Running C Programs in Zeus
Consider this simple test.c program:
#include <stdio.h>
int main()
    printf("Hello World.\n\n");
    printf("Press Any Key to Continue......\n");
    getchar();
    return 0;
If you compile, link and run this code inside Zeus you'll be presented with a console window that is empty.
Inside that console window pressing a key then results in this output capture inside Zeus:
Hello World.
What is causing this strange behaviour is the running test.exe executable is buffering it's standard output.
To fix this behaviour make the following code change:
#include <stdio.h>
int main()
    // stop stdout from being buffered
    setbuf(stdout, NULL);
    getchar();
    return 0;
