Windows 10 Zeus crash with Lua
kmhappel
Post by kmhappel »
The program resists saving files asking if you want to discard changes left in the editor when there are none known. Several save attempts causes Zeus crash. Using your Lua compiler and an add-in middleclass.lua for oop programing. Zeus version 3.98h. Windows 10 home version 1607
This shows up in the debug window.
...Owner\AppData\Roaming\Xidicone\Zeus\zScript\lua_exec.lua:65: bad argument #1 to 'remove' (string expected, got function)Macro script generated '1' Debug, Error and/or Warning message(s).
"zfwdoc01.cpp" (1543)
Re: Windows 10 Zeus crash with Lua
Zeus comes with an Lua interpreter as shown below:
C:\Program Files (x86)\Zeus>lua52.exe -v
Lua 5.2.0  Copyright (C) 1994-2011 Lua.org, PUC-Rio
But that interpreter is only used to do the Lua syntax checking and to run external Lua code.
It is only provided for the sake of simplicity and can be remove if required.
But if you do remove that lua52.exe file then you will need to edit the Lua Document type and in the Compiler section change the compiler command line.
The defauult command line is shown below, which as you can see is using this default Zeus Lua interpreter:
lua52.exe -v -p "$fn"
You will also need to edit the zScript/lua_exec.lua file and change this line of Lua code:
-- the 'run script' command will use tee to capture the output to a file
local cmd = "lua52.exe " .. file_name .. " 2>&1 | tee " .. file_output
Just change those two command lines to match whatever Lua interpreter you wish to use.
This error message is highlighting a bug in the lua_exec.lua Zeus script :oops:
From within Zeus create a new, empty document and into that document paste in this text:
lua_exec.lua:65
With the cursor on that line, use the View, Open File 'lua_exec.lua' menu to load that file at the correct line location.
Now change this broken Lua code:
   -- remove the output file
   os.remove(file_output_ex)
changing it to this correct Lua code:
   -- remove any previous output file
   os.remove(file_output)
This should stop the error message described earlier from happening.
With regard to using the middleclass.lua library found here: https://github.com/kikito/middleclass/
The link above contains the following example Lua code:
local class = require 'middleclass'
local Fruit = class('Fruit') -- 'Fruit' is the class' name
function Fruit:initialize(sweetness)
  self.sweetness = sweetness
Fruit.static.sweetness_threshold = 5 -- class variable (also admits methods)
function Fruit:isSweet()
  return self.sweetness > Fruit.sweetness_threshold
local Lemon = class('Lemon', Fruit) -- subclassing
function Lemon:initialize()
  Fruit.initialize(self, 1) -- invoking the superclass' initializer
local lemon = Lemon:new()
print(lemon:isSweet()) -- false
Save this code to a c:\temp\test.lua file.
To compile and run this code in Zeus make sure you download the middleclass.lua file from the link above and make sure it is save to the zScript folder.
You can locate zScript folder using the Tools, DOS Command Line menu and running this command:
dir $zScript
Then with the c:\temp\test.lua file as the active document, run the code using the Macros, Execute menu and you will then see the expected false output.
The next Zeus release will also include a change to allow the middleclass.lua file to live in the same folder as the file being executed.
kmhappel
Post by kmhappel »
Thanks so much... the bug fix worked... I had already figured out the zScript position for middle class. Do all extensions go there until next release?
Love the product
I am unable to get CVS going at all. Doxygen doesn't function either... seems the lack of .h and .c file throws it into a fit.... I read and followed your instructions letter for letter according to the setup guide and your knowledgebase... Do you have any suggestions.
I have not tested this, but I think if you setup a system wide LUA_PATH as shown below that should also work:
LUA_PATH=.\\?.lua;
Naturally you can point that LUA_PATH to point any any set of folders tat you like.
I will do some testing of these two features just to make sure they still work. These features were added to Zeus many years ago so it might be they have some issues with Windows 10 :?
The issue with Doxygen might be it doesn't work with Lua code.
I've only every used Doxygen with C, C++ and C# code and the last time I tried using it for such code I found it work well.
As I suspect Doxygen does not support Lua straight out of the box:
https://www.stack.nl/~dimitri/doxygen/helpers.html
I tried the first Doxygen filter for Lua listed on that page which can be found here:
https://github.com/alecchen/doxygen-lua
But when I tried to run the make command if failed:
C:\Temp\Lua>perl Makefile.PL
Can't locate inc/Module/Install.pm in @INC (you may need to install the inc::Mod
ule::Install module) (@INC contains: C:/Utilities/Perl/perl/site/lib C:/Utilitie
s/Perl/perl/vendor/lib C:/Utilities/Perl/perl/lib .) at Makefile.PL line 1.
BEGIN failed--compilation aborted at Makefile.PL line 1.
So it should be possible to make Doxygen work with Lua but this particular GitHub code dates back to 2010 so it may no longer work :(
I found a more recent version of this package here: http://annocpan.org/~ALEC/Doxygen-Lua-0.04
But the next step of the install fails because I have no make tool installed.
So I suspect this package is designed to work on Linux and lot on Windows.
I found a Doxygen Lua filter that works :)
The details can be found here: viewtopic.php?t=7597
I can confirm that the CVS plug-in is currently not working.
This should be fixed by the time of the next release due at the end of the month.
PS: For an alternative source control option there is also the Agent SVN Subversion plug-in found here.
This plug-in is known to work since it is actively used in the Zeus software development process ;)
