MS Access support
gjeudy
MS Access support
Post by gjeudy »
Does this SVN plugin support MS Access development? I have an .mdb file and I would like to put the embedded visual basic code under version control.
PS: I know MS Access should be compatible with SCC interface.
Thank you,
Guillaume
Re: MS Access support
While MS Access does have some form of MS-SCC interface, unfortunately I was not able to get it to work with Agent SVN :(
But some time back a provider of a MS-SCCI plug-in specifically for MS Access asked for help getting to get that plug-in to work with Agent SVN and Subversion.
That help spanned several weeks and it appeared to be going in the right direction, but I'm not sure what was the final outcome.
But you could ask them directly as this is their web site: http://www.ivercy.com/
In any case as you will see from that site, they claim to have a MS-SCCI plug-in for MS Access.
