If I am understanding things correctly, I believe that Zeus can be set up to do Java. Could you point me in the direction where you outline how to set it up for Java?
What a wonderful piece of programming software Zeus is.
Doing Java
Re: Doing Java
Never mind. I found the info easily on this site. You know I've tried lots and lots of code editors and many of them are just frightening to get set up. That's why I'm so amazed at how easy it is to set up Zeus. By the way I am just a hobbyist at this. I do it just for fun.
Re: Doing Java
I'm glad to read you are enjoying the experience of working with ZeusWhat a wonderful piece of programming software Zeus is.
As I think I mentioned in one of your earlier posts, at first Zeus can seem overly complicated, but after a little bit of reading and some playing, it does get a lot easier to understand.That's why I'm so amazed at how easy it is to set up Zeus.
It also looks like you are getting over that first hurdle, starting to get a hang of how Zeus works and seeing how easy it is to get Zeus working with pretty much any programming language.
If you like playing with programming languages, there are plenty left that you can try
