Slow autocomplete in Go?
I'm trying to use Zeus with Go and it seems autocomplete for APIs that are a core part of Go are very slow (>2 seconds after typing "."). I've reproduced this behaviour on two different machines.
Has anyone else seen this or is this a known issue? Any workarounds/fixes? I've tried explicitly creating a tags database from my local Go installation src just to see if it would help but it didn't.
thanks,
Zac
thanks,
Zac
Re: Slow autocomplete in Go?
I suspect this could well be an issue with gocode itself and luckily this is fairly easy to test.
In the Zeus, gocode.py macro script file there is this code:
That macro file is found here:
Change that code by adding a debug message box as follows:
Now if you replicate the autocomplete issue the message box will display the gocode command that is about to be run.
At this point don't close the message box, but instead use the Ctrl+C command to copy the message details.
Now in a second Zeus session paste that code into an new document, extract the gocode command line, open a new DOS prompt and run that command in the DOS prompt.
If this is a gocode issue the same command will take several seconds to complete inside the DOS prompt.
def gocodeExecute(fmt):
# set [<name> [<value>]] list or set config options
command = "gocode.exe -f=" + fmt + " -in=" + file_name + " autocomplete " + str(cursor)Code: Select all
C:\Users\<current user>\AppData\Roaming\Xidicone\Zeus\zScript\go_code.pyCode: Select all
zeus.message_box(0, command, "Go Code Test")At this point don't close the message box, but instead use the Ctrl+C command to copy the message details.
I'll try out what you've mentioned below. I should note that I have not found the same problems in either Sublime Text's auto-complete with Go or Atom's auto-complete with Go.
jussij wrote:I suspect this could well be an issue with gocode itself and luckily this is fairly easy to test.
... SNIP ...
Since this is core information, can you create a simple test file that replicates the issueI'm trying to use Zeus with Go and it seems autocomplete for APIs that are a core part of Go are very slow
For example when I auto-complete on fmt in the example code below, it returns with the results in well under a second:
package main
import "fmt"
func main() {
fmt.
}I haven't uses Sublime or Atom, but I would have though they too use gocode for auto-completion, so I would have thought the speed would be roughly the same
If you post the details of the test above or a sample file that replicates the issue, I'd be happy to take a look.
Could you also check task manager to see how many versions of gocode.exe are running
The Zeus macro is only meant to start gocode.exe if it is not already running (hence the first up pause you get on the first autocomplete).
But I have heard reports of cases where there was more than one instance of gocode running.
So I tried your test and it was quite slow the gocode.exe that's installed with Zeus. I tried fetching my own copy of gocode.exe from the git repo and it was much faster.
That said, when I tried replacing the gocode.exe in the Zeus installation folder with the one I fetched, it never really worked at all. Spun the little "busy" spinner a lot, started an instance of gocode.exe but then did nothing
The sample code is nothing special...
I may try uninstalling and reinstalling to see if that makes a difference at all. Not sure what's up.
package main
import (
"syscall"
func StupidFunc() {
derp := syscall.
So it does sound like there is something wrong with the gocode.exe
I would not do the uninstall/re-install as the only thing you need to change is that single gocode.exe file.
Nothing else should be effecting this.
As another test you could try this version: http://www.zeusedit.com/z300/gocode.zip
That is the gocode.exe that I have installed and it seems to work fine on Windows 10, 64 bit.
Scrap that suggestion.
Running your simple test I can also see that massive delay in autocomplete
That suggest you are running the same gocode.exe as me.
The version that comes with the Zeus installer was updated to using the latest gocode release only quite recently.
I suspect something in that new release might be broken.
I'll try to test that by trying to locate an earlier version of gocode and repeat your test.
This might be a bug in Zeus or the Zeus Go macro
Check back in a little while and I might have an answer to this riddle
This issue was caused by some sort of deadlock issue in the Zeus gocode Python script.
That Python code was fairly old and was using an older process handling method. Looking into the Python documentation for that API it warns of possible deadlocks.
So I have re-written the script to use the newer, recommended Popen approach and that seems to have fixed the issue.
Here is the new go_code.py file that needs to replace the same file in the zScript folder: http://www.zeusedit.com/z300/go_code.zip
This is the location of the zScript folder:
And this is the latest version of gocode that works just fine with that new script: http://www.zeusedit.com/z300/gocode.zip
C:\Users\<Current User>\AppData\Roaming\Xidicone\Zeus\zScriptCheers Jussi
