Moving Cursor
Vektoren
Moving Cursor
Post by Vektoren »
Dear all,
I am a new user to Zeus and use the current version 3.98aa. I noticed today, that the cursor is moving if I scroll through a file. The obvious expectation is that the cursor stays, even if I scoll. I cannot find any editor option to change this behaviour. Is this a bug or a feature? :)
Details:
Lets say, the cursor is at line 1000 and this line is also at my viewport. If I scroll now towards the top, the cursor scrolls with the viewport and, thus, the cursor's position gets changed continuously.
Best regards,
Thorsten
Re: Moving Cursor
Hi Thorsten,
This is nothing new to the version you are running as this behaviour has been in Zeus right from the beginning.
I call it a feature, but others might call it a bug ;)
Some history. Having been brought up using Brief on OS/2, I'm very much a keyboard user.
After moving to Windows I found two things. Brief ran poorly and I found this new scroll feature that would always catch me out.
I would scroll page after page using the mouse, only to then lose that page, because I would always forget to click the mouse before hitting a keyboard key.
So when I decided to write a Brief clone for Windows (called Zeus) I made sure it would stop me making that mistake again ever again.
That is the behaviour you are seeing.
Yes, Zeus will always keep the cursor somewhere on the screen.
