[Evaluation Questions] Workspace & License
Vektoren
Post by Vektoren »
Dear forum,
I evaluate the Zeus IDE in order to develop e.g. Go and D programs. Therefore, I have at the moment two questions:
  • Let's say that I start to develop a new program, thus, I create a new workspace & project. Afterwards, I create a new file and store it within the workspace's directory. Unfortunately, it does not appear at the workspace nor project afterwards. Thy only way, that the file occurs there, is to add it manually by use "Add files to project..." or "Add current file to project". Is there a solution to keep the project in-sync with the corresponding directory at the file system? Or, at least, to add new files directly to the project?
    What I also observed: If I create a new folder within the project by using the Zeus IDE's function -- the folder does not appear at the file system. This behavior is somehow wired to me.
    Therefore, the workspace & project seem to completely independently from anything. :P Maybe, I just do not get the point i.e. idea behind :wink: Can someone advise me? :D I think my expectation is a behavior like e.g. with Visual Studio.
  • If I buy a license for Zeus IDE, can I register the IDE on two machines e.g. my desktop machine & my laptop? Thus, is it a license for a user or for a machine?
Best regards,
Thorsten
Re: [Evaluation Questions] Workspace & License
Hi Thorsten,
That is correct.
One option is to create a Zeus macro that creates or updates the Zeus workspace and project files.
There is an example of such a macro for the Go Build (gb) tool found here: viewtopic.php?t=7495
That macro will create or update a Zeus workspace based on gb rules.
Another option is to drag and drop files/folders from Windows Explorer and drop them onto the required Zeus project node.
This is by design.
The folders in the Zeus workspace are just filters or groupings and they can, but they don't have to map to physical folders. They can be physical or virtual.
It is just a structure that allows you to organise and group files. For example the same file can exist in many workspace locations.
The reason it is done this way is by design, as it means Zeus does not every touch or change the structure of the file system.
This means Zeus can never do damage your file system :)
Visual Studio has a similar concept of filters that do not map to folders (only for existing items).
But Visual Studio, unlike Zeus, will create and delete files and folders when asked to do so. Zeus doesn't ever do this.
Yes. It is one license per user, not per machine.
PS: Zeus also imports Visual Studio solution files.
Vektoren
Post by Vektoren »
Dear Jussi,
Thank you very much for the information. After a few more hours of evaluating with different languages I am now fine :D The idea of workspaces & projects which are not influencing the file system's structure is very good. I am convinced and want to buy a license now :)
Best regards,
Thorsten
