I'm evaluating AgentSVN 2.47 as PushOK replacement for Rational Rhapsody in my company.
As we are using SVN 1.7 I use TortoiseSVN in an appropriate version (TortoiseSVN 1.7.13, 64 Bit / Subversion 1.7.10), I configured AgentSVN to not use the internal svn tools.
If I try to commit changed files from Rhapsody, nothing really happens. I looked into the log file and I think I found the problem:
[Mon Aug 10 16:14:31 2015] >> * Command: svn.exe --non-interactive --trust-server-cert commit --no-unlock -m""My commit message
"" --changelist CL-25962575
[Mon Aug 10 16:14:32 2015] >> svn.exe: invalid option: Code: Select all
svn.exe --non-interactive --trust-server-cert commit --no-unlock -m "My submit message" --changelist CL-25962575Could you please fix this issue?
Best regards
Timo Steuerwald
