New (potential) user here.
I have a fortran program which uses an external module. When I try to compile the module I get an error saying it already exists which isn't true.
I don't see any way to link the program to the module unless it happens automatically.
I need to increase the font size but the help file says options > font size and there isn't such a choice on the menu.
Roger
compiling problem
Re: compiling problem
I found the font control so that's ok now.
Roger
Roger
The compile error is this which is not much help to me at least
c:/program files/gfortran/bin/../lib/gcc/mingw32/4.10.0/../../../libmingw32.a(main.o): In function `main':
e:\p\giaw\src\pkg\mingwrt-4.0.3-1-mingw32-src\bld/../mingwrt-4.0.3-1-mingw32-src/src/libcrt/crt/main.c:91: undefined reference to `WinMain@16'
collect2.exe: error: ld returned 1 exit status
Roger
Roger
Hi Roger,
To me that looks like the WinMain function was not found by the linker.
For example the C#, C/C++ and Go document types all have similar configurations.
So there is no special FORTRAN only settings in Zeus to let you do this configuration.
But since it is always possible to run the FORTRAN compiler from the command line and have it do just this, that means the same configuration could be configured and run from inside Zeus.
So the question is how would you run the gfortran compiler if you was doing this from the command line. What would that command line look like
How do you normally run your builds
Do use use a make file or a build tool or just a batch file
I'm no expert in FORTRAN but from the error message this does look like a linker issue:The compile error is this which is not much help to me at least
The default command line defined for the FORTRAN document type is setup to take a single file and create an executable from that file and this is generally true of most of the Zeus document types.I don't see any way to link the program to the module unless it happens automatically.
