AgentSVN Version 2.47
A call to SccGetProjPath causes AgentSVN to get all the files from the module in the repository to the local folder, selected in the dialog.
I consider this behavior to be incorrect as SccGetProjPath should not be getting any files. It should only establish the relevant paths and return them to the caller.
This bug affects me rather severely.
Call to SccGetProjPath causes a get of files
Re: Call to SccGetProjPath causes a get of files
Hi Phil,
Could you do the following:
1. Start the Agent SVN Configuration tool
2. Turn on the 'Help debug the SVN setup...' option
3. Click on the View Log File Button
4. Copy the last line of the file which is the file location
5. Truncate the contents of that debug file
6. Replicate the issue
7. Send me the log file as an e-mail attachment
8. Turn off debugging as leaving it on causes big performance issues
