Hello,
I am using version 3.97u. There is a relatively new feature to automatically check out files from source control on an edit which I hate. When I turn it off, the feature stops as expected. However, if I stop and restart zeus, this option is always checked again. I assume it is a bug that unchecking this option is not remembered between invocations.
Thanks!
Jack
AUto checkout file problem
Re: AUto checkout file problem
Hi Jack,
I can confirm that this is also a bug in the latest Zeus 3.97x release
I'll look to get this fixed ASAP.
The Zeus beta version found here should fix this issue: http://www.zeusedit.com/z300/ze-beta.zip
IMPORTANT: don't forget to make a backup copy of your current Zeus installation.
Thanks you so much, this fixes the problem.
