The dfmt utility is code formatter for the D language and it's possible to configure Zeus to run gofmt each time the file is saved.
To make this work perform the following steps:
1: The first thing you need to do is build dfmt and add the resulting executable to the to the Zeus install folder.
The dfmt code found here: https://github.com/Hackerpilot/dfmt
2: Install the script found here.
That link contains details on how to install the script.
3: Use the Options, Document Types menu and edit the D Document Type and in the Triggers section add the d_dfmt.lua macro saved from the previous step to the File Save Postfix trigger field.
So How Does it Work?
The Zeus file save trigger allows a macro to be attached to any file save event and in this case the d_dfmt.lua macro is configured to fire whenever the file is saved.
NOTE: Other Zeus, D language specific features can be found here:
Using the Dscanner (D Language) inside Zeus
Using the D Programming Language with Zeus
Using the DCD with Zeus
