xtags - search for references
drprav
Post by drprav »
Hi
To search for all references to a keyword (variable or function name) in a project, I right click on the keyword and select "File Grep" option. This opens a dialog but I have to everytime change the Directory to point to the top level directory of the project. And I have to everytime add the '-d' option to Arguments to search all the sub-directories.
Is there a registry entry or something where I can make these changes permanent and as the default values for "File Grep"?
The output of this is shown in a Tools tab along with the other open files. Is there any way I can redirect the output to some other fixed window so I can easily move between the search result and the source files without having to toggle between the tabs...?
And finally, is there any other better way to search for references?
Praveen
Hi Praveen,
There is no registry entry but it is easy to write a macro to achieve the same effect. For example the following grep.lua macor script will do something similar:
  local directory;
  -- NOTE: The $PDD drive and directory maps to the value specified
  --       in the "Project make file" entry field found in the General
  --       Section of the Workspace
  directory = macro_tag("$PDD")
  -- NOTE: The $WDD drive and directory maps to the current workspace
  --       drive and directory
  directory = macro_tag("$WDD")
-- some debug help
-- message_box(1, "Debug", directory);
  -- assume search word is current word or marked area
  local word = macro_tag("$WEX")
  if string.len(word) == 0 then
    -- no word found so ask for a user for a search word
    word = user_input("Search String:", word)
  if string.len(word) > 0 then
    -- the files to be searched
    local files_extensions = "*.cpp *.hxx *.h"
    -- ask for a user for a command line
    local cmd = "xfgrep.exe -d -f -n " .. word .. " " .. files_extensions
    -- setup command control falgs (see the Zeus Macro help for details)
    local flags = 2+4+16+32
    -- run command
    system(cmd, directory, flags)
Just save the grep.lua to the zScript directory found in the Zeus install directory. To run the script use the Macro, Execute Scripts menu and type in grep.
It is also possible to add the macro to the Zeus Macro and/or popup menus or alternatively bind the macro to the keyboard.
In the case above the output should always end up in the same Tool window. You can also control the window creation using the file_open_tool macro function. For more details see this thread:
http://www.zeusedit.com/forum/viewtopic.php?t=74
I find xgrep.exe is my favourite way of searching for references ;)
The Tags, Find menu can be used to search for declarations but unfortunately it will not find references :(
But since Zeus can easily integrate any external command line tool, if you search the web for a xref tool it should be easy enough to integrate this into Zeus.
drprav
Post by drprav »
Thanks Jussi!
The macro is working great. I was able to add it to the Zeus Macro menu, but am not able to add it to the right click popup menu....any ideas of how to go about it?
I am trying to use Zeus in place of another editor, Visul SlickEdit, which has very powerful referencing tools. Zeus is almost there (and much cheaper!) except for not having all the references listed in a separate fixed output window pane from where I can double click the line and it opens the relevant file. If I re-redirect the output to a DOS window, I will not be able to use the double click functionality.
With Regards,
Praveen
If you edit the document type where you added the macro, in the macros panel you should see an Add to popup menu. This will add the macro to the popup menu.
Zeus should be able to capture the grep output to a tool window and let you double click to take you to the correct file and line. If this is not working then theconfiguration is not quite right :(
