I want TABs instead of SPACEs at the start of lines.
I have disabled "Tabs as spaces" (actually tried it both ways).
I have disabled everything possible on the Template properties tab.
And yet ... Zeus keeps on mixing TABs and SPACEs at the start of the line,
often with a TAB or 2, followed by SPACEs once it thinks that I'm indenting passed the start of "overhanging" code.
I've tried remapping the Enter key from "EnterSmart" to just "Enter", and while that fixes some other annoyances, this behavior persists.
How can I get Zeus to stop doing this?
How can I actually disable auto-indent.
This SmartPaste issue has been fixed in the beta version found here: http://www.zeusedit.com/z300/ze32-beta.zip
With this change the SmartPaste will pad the lines based on the setting of the Tabs as spaces option found in the document type.
