Session?
effemmeffe
Session?
Post by effemmeffe »
As I already said in another post I came to Zeus from MultiEdit and I'm trying to understand if there are some ME behaviour I can replicate in Zeus.
I like to have one session for each SW project and every time I switch project I just change session and then every opened file is there, every search is limited to the session files and so on.
Is there some similar feature in Zeus?
Not being familiar with ME it's hard to say :?
Zeus has a workspace which is a lot like the Visual Studio workspace or solution.
Basically a workspace is a a collection of one or more projects and by using the Workspace menu it is very easy to switch workspaces. You can also switch Workspaces from inside Windows Explorer (and making a registry change that behaviour can be change to opening workspace in a new Zeus session if required).
It also possible to limit a search for files and/or text to a workspace via a macro script. In fact there are already two such macros on the Macros menu.
Finally when you switch workspaces any open files will be attached to workspace and the M.R.U. list is also attached to the workspace.
PS: At the end of last year, wraith808 did a fairly in-depth review of Zeus which can be found here.
I think this well written review is for a pretty good summary of what Zeus can and can't do and it is written from the perspective of a user new to Zeus.
