Quote Marked Area
Quote Marked Area
The macro below is designed to be bound to the quote (") character using the Options, Editor Options menu, Keyboard Mapping panel.
The macro will wrap any marked region of text in quotes.
--        Name: Add Quote to Marked Area
--    Language: Lua Macro
-- Description: This macro is designed to be bound to the quote character
--              and it will wrap the marked area in quotes. If no marked
--              area is defined it just passes the event to the default
--              keybaord handler.
  local processed = false
  if is_document() == 1 and is_read_only() == 0 then
    if is_marked() == 1 then
        -- disable screen updates
        top    = get_marked_top()
        left   = get_marked_left()
        bottom = get_marked_bottom()
        right  = get_marked_right()
        mode   = get_marked_mode()
        -- remnove the marked area
        MarkHide()
        -- insert the trailing quoted
        set_line_pos(bottom, right)
        print("\"")
        -- insert the leading quoted
        set_line_pos(top, left)
        print("\"")
        -- adjust the end of the marked region
        if top == bottom then
            right = right + 2
            right = right + 1
        -- apply the new marked region
        set_marked_area(mode, top, left, bottom, right)
        -- restore screen updates
        -- processing complete
        processed = true
  if processed == false then
    -- let the default handle the quote char
    keyboard_default("\"")
