cannot find macro trigger file
ianbryant
Post by ianbryant »
After installing 3.97s I now get this error message pop up at the bottom of the screen
Error loading the "c:\users\xxx\AppData\Roaming\xidicone\Zeus\zscript\c:\users\xxx\AppData\Roaming\xidicone\Zeus\zscript\go_fmt_on_save_postfix_event.py" macro trigger file
It looks like the path to this file is has been set twice in some hidden variable ?
Use the Options, Editor Options menu and in the Triggers panel set the File Save Postfix value to this:
$zud\zScript\go_fmt_on_save_postfix_event.py
or set it to blank.
