Mouse Click Append Line to Clipboard
This mouse click event macro will append the current line of text to the clipboard whenever the mouse is clicked on the line of text.
Refer to the description below on how to use the macro.
--        Name: Mouse Click Append Line to Clipboard
--    Language: Lua Macro
-- Description: The click event macro will append the current line of
--              text to the clipboard.
--              To use the macro use the Options, Editor Optiosn menu
--              and in the Triggers panel add this to the Mouse Click
--              trigger:
--                   $zud\zScript\event_mouse_copy.lua
--              That line assumes the macro is saved to the zScript
--              folder as the event_mouse_copy.lua file.
    if (is_document() == 1) then
        -- look for the line number
        for i = 1, argc(), 1 do
            -- Mouse Y argument will hold the line number
            local index, length, line = string.find(argv(i - 1), "MouseY=([%d:]+)")
            -- look for the line number argument
            if line ~= nil then
                -- append the line of text to the clipboard text
                local text = get_clipboard_text() .. get_line_text(line) .. "\n"
                -- put the combined text back into the clipboard
                set_clipboard_text(text)
                break;
        message("This macro only works for document files.");
        beep();
    -- fire the default handler any any case
    set_return_code(0)
