Does AgentSVN work with Powerbuilder 9?
jeffdd
Post by jeffdd »
I'm charged with setting up a development environment for a Powerbuilder application and would like to consider using AgentSVN, but I am tied into using Powerbuilder 9 for development.
When attempting to perform the Agent SVN setup/configuration instructions for Powerbuilder within version 9 I see some Agent SVN Info: messages as follows:
---------- Source Control
2/27/2014 09:55 Source Management Initialization...
Agent SVN Info: Caller Name: PowerBuilder
Agent SVN Info: Log File: C:\Users\jthompson\AppData\Local\Xidicone\Agent SVN\AgentSVN.log
Agent SVN Info: User ID: jthompson
Agent SVN Info: Current User ID: jthompson
Agent SVN Info: SccOpenProject Complete
Non Specific Error performing SccOpenProject.
Source control is in offline mode.
Restoring SCC Offline Status Cache from last backup.
Unable to initialize SCC status cache from backup C:\Users\jthompson\Documents\HDS\TestPBApp\test_workspace.pbc.
Initialization of Agent SVN Failed
---------- Done Source Control
jeffdd
It does!
Post by jeffdd »
After playing with it a bit more I can confirm that it appears I got this to work.
I will continue to test and post follow-up should I find any that relates to PB9.
Thank you for taking the time to post your feedback. Much appreciated :)
