Search and Replace Macro
The macro below will do a search and replace by showing and then hiding the search and replace dialog.
During the search and replace it will prompt the user for search and replace input via the status bar.
--        Name: Search and Replace Macro
--    Language: Lua Macro
-- Description: This script shows how to write an alternative search and
--              replace macro function. This macro will take user input
--              from the status bar.
    local locked = is_read_only()
        beep();
        return;
    -- the default search text
    local nill = ""
    -- ask for a user for the search and replace details
    local find_text, replace_text = user_input("Find Text:", nill, "Replace Text:", nill, "Find and Replace Dialog")
    -- check for user input
    if string.len(find_text) > 0 then
        -- save current search settings
        search_options_save()
        -- save the current cursor details (optional)
        --cursor_save()
        -- set the find and replace details
        set_find_text(find_text)
        set_replace_text(replace_text)
        -- set the other search options
        set_search_option("UseCase"   , 0)
        set_search_option("WholeWord" , 0)
        set_search_option("RegExpress", 0)
        local found = SearchNext()
        if found == 0 then
            message("Text not found: " .. find_text);
            -- decimal values of user input (see Tools, ASCII Chart menu)
            local ALL_KEY_U     = 65       -- A
            local ALL_KEY_L     = 97       -- a
            local REPLACE_KEY_U = 82       -- R
            local REPLACE_KEY_L = 114      -- r
            local NEXT_KEY_U    = 78       -- N
            local NEXT_KEY_L    = 110      -- n
            local QUIT_KEY_U    = 113      -- Q
            local QUIT_KEY_L    = 81       -- q
            -- loop here asking the user for input
            while found == 1 do
                -- show the text found
                -- ask the user for input
                message("R)eplace N)ext A)ll Q)uit")
                -- get the user keyboard input response
                local key = keyboard_input()
                if key == ALL_KEY_U or key == ALL_KEY_L then
                    -- replace all
                    while found == 1 do
                        found = ReplaceNext()
                elseif key == NEXT_KEY_U or key == NEXT_KEY_L then
                    -- next
                elseif key == REPLACE_KEY_U or key == REPLACE_KEY_L then
                    -- replace and search next
                    -- quit
                    message("Search and replace is complete.")
                    found = 0
            -- restore the cursor details (optional)
            -- cursor_restore()
            search_options_restore()
        message("Search and replace cancelled by user.")
