ascii character set
alan_m
ascii character set
Post by alan_m »
Hi
I have a file from another source. This file I believe has some hidden characters in it apart from 'space'. Is it possible from loading this file into zeus to see all characters from the ASCII set?
regards
Alan
Provided the file does not contain null characters (i.e. zero) it should load.
Files containing null will be loaded but marked as read only because the nulls will be converted to space during the load.
alan_m
Post by alan_m »
Hi, is it possible to show the characters? I can see white space but thats all
regards
alan
What you see is not dependent on Zeus but rather the font you have currently selected in the Zeus options.
Not all fonts define all the characters in the ASCII range.
As an example of this if you select the Terminal font then the text will be display using Code Page 437 which is a code page made famous by IBM MS-DOS PC.
http://en.wikipedia.org/wiki/Code_page_437
