The Alt+C in Zeus should be working. But you do need to make sure the Brief keyboard mapping is active, by using the Options, Editor Options menu and changing to the Keyboard section.
I have the Brief keyboard mapping active but it still doesn't work. When I attempt to use Alt+C, I see the Windows Menu Items become active indicating that the window is still using the Alt shortcuts.
Use the Options, Editor Options menu, edit the Brief or BriefEx keyboard mappings and bind the MarkColumnToggle keyboard function to the Alt+C key combination.
Brief is currently the active keymap and when I edit the Brief keymap Alt+A and Alt+C are already listed in the "Currently assigned" list for MarkColumnToggle. Is this working for you?
