Setting up the Borland 5.5 C/C++ Compiler
To setup Zeus to work with the Borland 5.5 C/C++ compiler do the following.
1) Go to this page and register for the download: http://forms.embarcadero.com/forms/BCC3 ... erDownload
That registration will result in an e-mail containing a download link.
Download and install the compiler from that link.
2) The installer would have installed the software in this folder location:
c:\Borland\BCC55
and the compiler and other tools are found in this folder location:
c:\Borland\BCC55\Bin
That bin folder needs to be added to the PATH environment variable. To do that use the Windows Control Panel to open up the System icon and use the Environment button found in the Advanced settings to add the bin folder above to the PATH environment variable.
To test this PATH change start Zeus and use the Tools, Command Line menu and run this command:
bcc32.exe
If that command generates the following output it means the PATH has not been set correctly:
'bcc32.exe' is not recognized as an internal or external command, operable program or batch file.
The expected output is this:
Borland C++ 5.5.1 for Win32 Copyright (c) 1993, 2000 Borland
Syntax is: BCC32 [ options ] file[s]     * = default; -x- = turn switch x off
  -3    * 80386 Instructions        -4      80486 Instructions
  -5      Pentium Instructions      -6      Pentium Pro Instructions
  -Ax     Disable extensions        -B      Compile via assembly
  -C      Allow nested comments     -Dxxx   Define macro
  -Exxx   Alternate Assembler name  -Hxxx   Use pre-compiled headers
  -Ixxx   Include files directory   -K      Default char is unsigned
  -Lxxx   Libraries directory       -M      Generate link map
  -N      Check stack overflow      -Ox     Optimizations
  -P      Force C++ compile         -R      Produce browser info
  -RT   * Generate RTTI             -S      Produce assembly output
  -Txxx   Set assembler option      -Uxxx   Undefine macro
  -Vx     Virtual table control     -X      Suppress autodep. output
  -aN     Align on N bytes          -b    * Treat enums as integers
  -c      Compile only              -d      Merge duplicate strings
  -exxx   Executable file name      -fxx    Floating point options
  -gN     Stop after N warnings     -iN     Max. identifier length
  -jN     Stop after N errors       -k    * Standard stack frame
  -lx     Set linker option         -nxxx   Output file directory
  -oxxx   Object file name          -p      Pascal calls
  -tWxxx  Create Windows app        -u    * Underscores on externs
  -v      Source level debugging    -wxxx   Warning control
  -xxxx   Exception handling        -y      Produce line number info
  -zxxx   Set segment names
3) Edit the Zeus C/C++ Document Type and in the Compiler section add this as the command line:
bcc32.exe -Ic:\Borland\bcc55\include -Lc:\Borland\bcc55\Lib "$fn"
The -I and -L options tell the compile where to file the include and library folders respectively and point to the folders found in the original install folder from above.
NOTE: The command line above will create a console Windows executable. If you want to build Windows GUI executable you will need to change the command line to be:
bcc32.exe -tW -Ic:\Borland\bcc55\include -Lc:\Borland\bcc55\Lib "$fn"
More documentation on other compiler command lines can be found here: http://edn.embarcadero.com/article/20997
4) Create a sample hello.cpp file as shown below:
#include <stdio.h>
int main(void)
    printf("Borland C++ 5.5 Compiler Example.");
    return 0;
5) Use the Compiler, Compile menu to compile that file and the resulting compile and link will produce a hello.exe file in the same directory.
6) Use the Macros, Execute 'hello.exe' menu to run that executable and you should see this output.
