another search and replace bug with newlines
gwgs
Post by gwgs »
if i use the search string
(CALL errorlog\()([A-Za-z0-9_.,' \[\]\\"\|\)\(\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n]+)(\)$)
and replacement string of
LET l_errormsg = \2\n      \1l_errormsg\3
with this piece of code
                      CALL errorlog("INSERT INTO stockdet(sdprodno, sdwhseno, sddet1, sddet2, \n",
                                   "sdcost, sddmyrec, sdexpiredmy, sdonconsign, \n",
                                   "sdsaleable, sdsupplier, sdsuppslip,sdordrno,\n",
                                   "sdohdqty, sdallqty, sdordqty, ",
                                   "sdborqty, sdforqty, sdconsignohdqty)\n",
                        "VALUES (", m_t1line[m_arr_curr].prodno CLIPPED, "|",
                                    m_thdr.twhse                CLIPPED, "|",
                                    l_sddet1_to                 CLIPPED, "|",
                                    l_select_from               CLIPPED, "|\n",
                                    l_stockdet_from.sdcost      CLIPPED, "|",
                                    m_thdr.trandmy              CLIPPED, "|",
                                    l_stockdet_from.sdexpiredmy CLIPPED, "|",
                                    l_stockdet_from.sdonconsign CLIPPED, "|\n",
                                    l_stockdet_from.sdsaleable  CLIPPED, "|",
                                    l_stockdet_from.sdsupplier  CLIPPED, "|",
                                    l_stockdet_from.sdsuppslip  CLIPPED, "|",
                                    l_stockdet_from.sdordrno    CLIPPED, "|\n",
                                    "0|0|0|0|0|0)")
i get the result of
                      LET l_errormsg = "INSERT INTO stockdet(sdprodno, sdwhseno, sddet1, sddet2,
                                    "0|0|0|0|0|0)"
      CALL errorlog(l_errormsg)
the \n in the code block gets translated to an actual new line
Grant
This is the same limitation as mentioned earlier: http://www.zeusedit.com/zforum/viewtopic.php?t=6982
Based on the Zeus internals, I'm not sure what could be done to fix this :?
Open to any suggestions.
