I am a new comer in Zeus IDE world. I install evaluation copy of Zeus 3.97p
1. I created new workspace with one python file
2. Click Classes view
I observed my class and local variables of all methods in my class. But I don't see any method of my class. Can I correct this situation
Alexander
Python question
jussij wrote:Could you post a sample of the python class with the methodCan I correct this situation
That will help me figure out why it is not working.
#!/usr/bin/env python2
import unittest
import os
import re
import ConfigParser
class join_unit_test(unittest.TestCase):
def setUp(self):
pass
def tearDown( self ):
pass
def test_join_unix_two_relative_path(self):
path1="./data/http-utility/"
path2="logger.config"
expect="./data/http-utility/logger.config"
result = os.path.join(path1, path2)
self.assertEqual(result,expect)
def test_join_win_two_relative_path(self):
path1=".\\data\\http-utility\"
expect=".\\data\\http-utility\\logger.config"
def test_join_unix_abs_relative_path(self):
path1="/data/http-utility/"
expect="/data/http-utility/logger.config"
def test_join_unix_abs_relative_path2(self):
path2="/data/temp/"
path3="logger.config"
expect="/data/temp/logger.config"
result = os.path.join(path1, path2, path3)
def test_join_unix_abs_relative_path3(self):
path2="/data/temp/"
path3="/data/temp2/"
path4="logger.config"
expect="/data/temp2/logger.config"
result = os.path.join(path1, path2, path3, path4)
def test_join_win_abs_relative_path10(self):
path1="c:/data/http-utility/"
expect="c:/data/http-utility/logger.config"
def test_join_win_abs_relative_path20(self):
path1="c:\\data\\http-utility\"
expect="c:\\data\\http-utility\\logger.config"
def test_join_win_abs_relative_path21(self):
path1="c:\\data\\http-utility"
def test_join_win_abs_relative_path22(self):
path1="c:/data/http-utility"
expect="c:/data/http-utility\\logger.config"
def test_join_win_abs_relative_path30(self):
path2="c:/logger.config"
expect="c:/logger.config"
def test_join_win_abs_relative_path40(self):
expect="c:/logger.config\\logger.config"
def test_join_win_abs_relative_path50(self):
path1="c:"
expect="c:logger.config"
def test_join_win_abs_relative_path60(self):
path1="c:"
path2=os.sep
expect="c:\\logger.config"
def test_join_win_path_space_path10(self):
path1="c:"
path2=os.sep
path3="logger config"
expect="c:\\logger config"
def test_join_win_abs_relative_path11(self):
path1="c:"
path2=os.sep
path3=" logger config "
expect="c:\\ logger config "
if __name__ == '__main__':
unittest.main()
