Ever since I upgraded to 3.97o, each time I open Zeus, it creates a debugger tab with the same message displayed several (200+) times.
Unexpected error loading debugger module. See the Debugger, Options menu for more details.
Everything else works fine.
						Get Debugger Error each time I open Zeus
For Windows 32 bit look here:
For Windows 64 bit look here:
These are the debugger modules you should have:
Check all these modules have the same date.
For any out of date or extra items just rename then to .dll.old and that should fix the issue.
If that does not fix the issue rename them all and then return them one at a time to find the culprit
C:\Program Files\Zeus\zDebugger\Code: Select all
C:\Program Files (x86)\Zeus\zDebugger\Code: Select all
C:\Program Files\Zeus\zDebugger\xdbGCC.dll
C:\Program Files\Zeus\zDebugger\xdbJava.dll
C:\Program Files\Zeus\zDebugger\xdbLua.dll
C:\Program Files\Zeus\zDebugger\xdbPerl.dll
C:\Program Files\Zeus\zDebugger\xdbPython.dllFor any out of date or extra items just rename then to .dll.old and that should fix the issue.
Those are the modules in the folder. They all had the same date. Jan-15-2013. I renamed them all to .dll.old but it still gives the error screen.
Zeus - Version 3.97o
Copyright (c) Xidicone P/L 1993-2013. All rights reserved.
