Feature request: separate scrollbar enabling
chris
Post by chris »
Can vertical and horizontal scrollbars be given separate enable / disable options? In the eternal struggle for maximum usable screen space it's nice to be able to switch off the (usually unnecessary) horizontal bar, but keep the vertical one.
cheers, Chris
I would say that it should be possible, but I will first have to take a look at the Zeus source code just to make sure. In any case the option has been added to the Zeus todo list.
The Zeus for Windows Version 3.94 release adds this new feature.
