try to compile a cobol program (from ibm), get this result
meirab
Post by meirab »
i try to compile cobol program from this url:
http://publib.boulder.ibm.com/infocente ... subw23.htm
and c program from this url:
and the result zeus gives is (for cobol):
Zeus - Version 3.97o
Copyright (c) Xidicone P/L 1993-2013. All rights reserved.
'cobol.exe' is not recognized as an internal or external command,
what do i have to do to resolve the problem?
What this means is the compiler command line has come out of the COBOL document type.
In other words Options, Document Types menu, COBOL document type, Compile panel.
'cobol.exe' is not recognized as an internal or external command, operable program or batch file.
This line means that Zeus tried running the cobol.exe on the current file but it could not find that executable.
This is to be expected because apart from a few of the Zeus document types, some form of one off user configuration is required.
So what would you need to do :?:
1) Make sure the cobol.exe is in the system PATH:
http://www.zeusedit.com/zforum/viewtopic.php?t=6176
Also from the link you provided:
2) Setup the COBOL environment variables:
3) Edit the compile command found in the Compiler panel mentioned earlier and set the compile command line options:
PS: The link that you provided describes an AIX COBOL compiler. Have you installed a X86 version of that compiler :?:
meirab
i try to find the cobol.exe with no success
Post by meirab »
and i try to set the path with: E:\Program Files\Zeus
and get the same result.
is zeus contains "cobol.exe" compiler or it must be installed some other way?
Yes, you need to install a COBOL compiler.
Here are a few options:
  1. OpenCOBOL - http://www.opencobol.org/
  2. COBOL for GCC - http://cobolforgcc.sourceforge.net/
  3. TinyCOBOL - http://tiny-cobol.sourceforge.net/
meirab
how can tinycobol configured to be executed from inside zeus
Post by meirab »
i have installed "tinycobol" at "c:" and the command: htcobol from:
C:\MinGW\local\bin
accepts the cobol program and has an output.
But i need to do it from inside "zeus" - how to define it inside zeus?
Just do this:
  1. Options, Document Types menu
  2. Select and edit the COBOL Document type
  3. Select the Compiler panel
  4. In the command line field add the command line shown below
    C:\MinGW\local\bin\htcobol.exe "$fn"
  5. You can also add any additional command line options. For more options see here: http://tiny-cobol.sourceforge.net/docs/htcobol_en.html
  6. Open a COBOL document and use the Compiler, Compile to compile and build that file
The above steps should create an executable in the same folder. You should check that this is the case.
If you now want to run that executable do this one off configuration to create a Tool item to run the executable:
  3. Select the Tools panel
  4. Setup this new tool:
         Menu Text: Execute: '$fb.exe'
      Program Name: $fb.exe
         Arguments:
    Work Directory: $fdd
    Turn on Capture Standard Output and Capture Standard Error options
    Add the item to the different menus as required
This will add a tool item to the Navigator, Tools panel (left side of editor).
After you have compiled your COBOL file you can now run the executable for that file from the Tools panel. To run the executable make sure the COBOL document is active and then use this new Tool item to do the run.
The output of the program should also get captured inside of Zeus.
