insert file
G74SX
insert file
Post by G74SX »
I am looking for a way to insert a file into a document being edited.
I found the fileinsert macro but it doesn't seem to work, or most likely I am not using it correctly.
There are several ways you can do this.
The first is to use the FileInsertAtCursor keyboard function which you can easily bind to any keyboard key combination.
Another option would be to write a custom macro script (like the file_insert macro).
I found the file_insert macro but it doesn't seem to work, or most likely I am not using it correctly.
I had a look at the macro and I think the issue is that the Lua io.open function has change between Lua versions.
To fix this open the file_insert.lua file and find this text:
-- open the file selected for text reading mode
local file_in = io.open(file_name, "r+t")
Change that code to read as follows:
local file_in = io.open(file_name, "r")
The macro should now work fine.
Thank you for taking the time to report the error in the script :)
G74SX
Post by G74SX »
The keyboard function works great.
Thanks.
polixx
Post by polixx »
I tried using the option one which is FileInsertAtCursor keyboard function and yes it really works! thanks for the inputs.
