diff command
alan_m
diff command
Post by alan_m »
am looking at the DIFF command, Do you have any documentation on how it works?
regards
alan
The Tools, Difference menu and the File, Difference menu are both launch the Difference dialog and that dialog is just a wrapper to the xDiff.exe tool found in the Zeus bin folder.
The xDiff.exe tool is pretty much a standard fiff tool.
In the Options, Editor Options menu, Miscellaneous panel there is a command line option for an external difference tool.
Here are some examples of such a command line:
"c:\Program Files\WinMerge\WinMergeU.exe" $f1 $f2
"c:\Program Files\DiffMerge\DiffMerge.exe" $f1 $f2
"c:\Program Files\Perforce\P4WinMrg.exe" $f1 $f2 $f1
To access that command line either make it the default action using the Miscellaneous panel, or use the View External button found in the Difference dialog.
