Insert String
Insert String
The following macro asks the user for an input value and insert that value into every line of the marked region.
--        Name: Insert Macro
--    Language: Lua Macro
-- Description: This simple Lua macro will replace a column marked area
--              with the text provided.
  local MARK_COLUMN = 0
  -- macro only works for column marked regions
  if is_marked() == 0 or get_marked_mode() ~= MARK_COLUMN then
    message("This macro needs a column marked area.")
  -- the initial value
  local initial_value = "0"
  -- ask for a user supplied decimal number
  local value = user_input("String Value:", initial_value)
  if string.len(value) == 0 then
    message("Operation cancelled by user!")
  local top   = get_marked_top()
  local range = get_marked_bottom() - top + 1
  -- disable screen updates
  -- delete the marked area
  MarkDeleteEx()
  -- number the lines selected
  for i = 0, range - 1, 1 do
    -- save the current cursor
    cursor_save()
    -- write out the value
    write(value)
    -- restore cursor
    cursor_restore()
    -- move to the next line
    MoveLineDown()
  -- restore screen updates
