Drag text bug
stanmkatz
Drag text bug
Post by stanmkatz »
When you drag text within a line and the destination is after the source, the text gets inserted at the incorrect point. In the following line if I select the ".value" and try to drag it to after the "beta"
alpha.value = beta + gamma;
I get
alpha = beta + gam.valuema;
instead of what I want which is
alpha = beta.value + gamma;
It looks as if you are not adjusting the destination column to handle the fact that the characters are effectively deleted.
Thanks for the bug report. I'll look to have this fixed in the next release.
This issue should be fixed in the Zeus download found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
