Using the Console2 Inside of Zeus
A simple macro to run the Console2 utility from inside of Zeus.
#        Name: Console2 Lua Script
#      Author: Jussi Jumppanen
#    Language: Python Macro
# Description: This Lua script creates a new Console2 console window from
#              within the Zeus IDE. It will create the console in the same
#              drive and directory of the active file. It will also maintain
#              the current working directory.
#                  http://sourceforge.net/projects/console/
import os
import zeus
import subprocess
def key_macro():
   # http://docs.python.org/library/subprocess.html
   # the installation folder for the Console.exe utility
   cmd = ["C:\\Workspace\\Zeus\\Console2\\Console.exe"]
   # add a caption to the window
   cmd.extend(["-w", "DOS Prompt"])
   # set the current working directory
   cwd = os.getcwd()
   cmd.extend(["-d", cwd])
   # the ditrectory of the active file
   directory = zeus.macro_tag("$FDD")
   if len(directory) > 0:
       # change to the directory of the active file
       os.chdir(directory)
       # add in the directory options
       cmd.extend(["-d", directory])
       # the drive letter excluding the '\' character
       drive = zeus.macro_tag("$FDR")
       # change to the correct drive
       cmd.extend(["-r", "cmd.exe /k " + drive])
   # run the console executable
   subprocess.Popen(cmd)
key_macro() # run the macro
