LUA script to global search and replace
mahub
Post by mahub »
Need some assistance creating a lua script to do multiple global replace on multiple strings. Not programmers but do have half a brain. Any help is greatly appreciated.
I am happy to try and help but you are need to going to be a bit more specific.
Are you do the search and replace over a single file or multiple files :?:
If it is multiple files, how are you deciding which files need to be processed :?:
When you say multiple strings, are the search and replace patterns fixed and if so what is an example of one such typical pattern :?:
If these patterns are not fixed where are you planning on getting them from :?:
The difficulty is there are so many ways to achieve this and depending on answers to the questions above will determine which of these many approaches is the easiest.
Finally, if you need to do tens or hundreds of individual search and replace actions then it might be better to use a tool like SED to do this work.
It is easy to run tools from inside Zeus macros, so it might be a good idea to write a simple macro that just runs SED and lets SED do all the heavy lifting.
mahub
Post by mahub »
One file at a time.
Most fixed. Example LA_ replace with NY_.
Thanks for all your help.
One file at a time.
In that case this is fairly straight forward.
The simplest way to do this is as follows:
    use_regexp = 0
    -- replace all text in current document
    replace_all("LA_", "NY_", use_regexp)
    search_options_restore()
But you could also implement this using this more long winded approach:
function replace_text(search, replace)
    -- set the search and replace details
    set_find_text(search)
    set_replace_text(replace)
    -- replace all the items in the document
    while ReplaceNext() > 0 do
    -- save current search settings
    search_options_save()
    -- different scope options
    SCOPE_FORWARD = 0
    SCOPE_REVERSE = 1
    SCOPE_MARKED  = 2
    SCOPE_ENTIRE  = 3
    SCOPE_ALL     = 4
    -- set the search options
    set_search_option("Scope"     , SCOPE_ALL)
    set_search_option("UseCase"   , 0)
    set_search_option("WholeWord" , 0)
    set_search_option("RegExpress", 0)
    replace_text("LA_", "NY_")
mahub
Post by mahub »
Thanks so much. I will give it a try.
mahub
Follow Up
Post by mahub »
Can you instruct me how to do it for multiple open files please?
The macro below will do the replace across all open, named document files.
    use_regexp   = 0
    delimiter    = '|'
    FULL_DETAILS = 1
    -- get all current document files delimited by the pipe character
    all_files = document_files(FULL_DETAILS, delimiter)
    current_window = get_window_id()
    -- split the all the files into their individual file names
    for file_name in string.gmatch(all_files, "([^|]*)|?" ) do
        -- activate the file window
        if window_activate_name(file_name) then
            -- replace the text in current document
    -- restore the original window
    window_activate(current_window)
