Prompt for filename creation
gwgs
Post by gwgs »
When zeus is called from the command line, is there an option/can there be an option to ask if to create the file?
if you accidentally type the wrong name when opening zeus you end up with a 0 length file named whatever you called it if you exit out without saving, can these 0 length files get removed automatically by zeus if no changes are made to these new files?
Grant
You should be able to do this using a file trigger. See the Options, Editor Options, Triggers panel.
