Numbers Macros
Numbers Macros
Below are three numbers macros. They will convert a column marked area into a incremental set of numbers based on the initial value provided by the user.
The difference in the three macros is the first produces a decimal, the second a hex and the third a hex mask series of numbers.
So for example if five lines are marked an the macro is run with an intial value of zero the macros will produce the following results:
Numbers Macro
1
2
3
4
Numbers Hex Macro
0x0
0x1
0x2
0x3
0x4
Numbers Mask Macro
0x01
0x02
0x04
0x08
0x10
Naturally if more or less lines are covered by the region of column marking then the series of numbers produced is adjusted accordingly.
--        Name: Numbers Macro
--    Language: Lua Macro
-- Description: This simple Lua macro will replace a column marked area
--              with a series of incremental numbers. To use the macro
--              column mark a range of lines and then run the macro.
--  How To Run: All Zeus macros can be run using the macro execute menu
--              item or they can be bound to the keyboard or they can
--              be attached to the macro drop down or popup menus.
  local MARK_COLUMN = 0
  -- macro only works for column marked regions
  if is_marked() == 0 or get_marked_mode() ~= MARK_COLUMN then
    message("This macro needs a column marked area.")
  -- the initial value
  local initial_value = "0"
  -- ask for a user supplied decimal number
  local value = user_input("Initial Value:", initial_value)
  if string.len(value) == 0 then
    message("Operation cancelled by user!")
  local top   = get_marked_top()
  local range = get_marked_bottom() - top + 1
  -- disable screen updates
  -- delete the marked area
  MarkDeleteEx()
  -- convert the string into a number
  local offset = string.format("%d", value)
  -- maximum number
  local max_number = range - 1 + offset
  -- the maximum length
  local max_length = string.len(string.format("%s", max_number)) - 1
  -- number the lines selected
  for i = 0, range - 1, 1 do
    -- build the number
    local number = string.format("%s", i + offset)
    -- save the current cursor
    cursor_save()
    for k = string.len(number), max_length, 1 do
      -- write out the padding
      write(" ")
    -- write out the number
    write(number)
    -- restore cursor
    cursor_restore()
    -- move to the next line
    MoveLineDown()
  -- restore screen updates
--        Name: Numbers Hex Macro
--              with a series of incremental hex numbers. To use the macro
  MarkDeleteEx()
  -- maximum number
    -- build the number
    local number = string.format('%X', i + offset)
    cursor_save()
    -- write out the prefix
    write("0x")
      write("0")
    write(number)
    -- restore cursor
    cursor_restore()
    MoveLineDown()
--        Name: Numbers Mask Macro
--              with a series of incremental left shifted bit values. To
--              use the macro column mark a range of lines and then run
--              the macro.
  -- macro only works for marked regions
  MarkDeleteEx()
  -- maximum number
  local max_number = 2 ^ range - 1 + offset
  local x = 1
    -- build the number
    local number = string.format('%X', 2 ^ i)
    cursor_save()
    write("0x")
      write("0")
    write(number)
    -- restore cursor
    cursor_restore()
    MoveLineDown()
