Problem with color highlighting
JackR
Post by JackR »
I just upgraded from 3.97D Beta to 3.97n Beta 12. There must have been a change to the color highlighting code in Zeus.
For C++ code, comments are displayed in blue.
I have a lot of old code I inherited and it has code that looks like this
int read_index; //* ptr's to next queue entry read */
In the current version of Zeus, the entire file after this line displays as a comment ( blue ). In the previous version, the color is correctly displayed after this line. Hopefully this can be fixed in Zeus. I hate the the thought of checking 1000's of files out and back into source control just to edit the comments.
if I change it to either of these, Zeus works correctly
int read_index; /* ptr's to next queue entry read */
Thanks!
Jack
Hi Jack,
I am not seeing the bug at this end :(
If I paste the code below into a new test.cpp file running the Zeus beta 12 it all colors just fine.
Some stuff .....
It looks like there might be something in you local Zeus configuration settings :?
To test this theory could you move the entire Zeus install folder out with a rename and then run the full installer found here:
http://www.zeusedit.com/z300/zeus-beta.zip
JackR
Post by JackR »
Your were correct, the virgin install does not have this problem. Instead of copying the zConfig folder over the new installation like I always have done, I manually configured the new install ( you greatly improved the default color selections so I didn't mind doing this work).
Thanks!
Jack
