Macro invocation key
pwdiener
Post by pwdiener »
Hi, Jussi
Is there a way to determine how a macro was invoked? Specifically, from the Execute Macro Script window, or from a keyboard mapping? It would also be useful to be able to tell WHICH key was used to invoke the macro.
My specific use is to combine my 4 error display macros into one, since there are only relatively minor differences between them and that would make the code easier to maintain.
It's quite possible that I'm trying to solve this problem the wrong way. I'll also see if I can get the LUA loadfile function to work for me as a means of accomplishing my objective, but the invocation key still seems like a potentially useful bit of data.
Bill Diener
Hi Bill,
From the keyboard the answer is no.
From inside the Execute Macro Script window you can pass arguments to the macro.
For example:
MyScript.lua argument1 argument2 argument3 ....
For more details search for the argv and argc macro functions.
To better share the common code you could create a base macro file containing the common code and then include that file into the other, now much smaller macro files.
There is aslo the dofile Lua function. See the uncomment.lua for details.
pwdiener
Post by pwdiener »
I've used argc and argv with event triggers, but never from the execute window. A useful thing to know...
This is probably a dumb question, but how do I "include" a macro function in another one? That would be fine with me, but I couldn't see a way to do it.
I know about dofile, and that would work if the code is organized a certain way. I got fixated on a "function library" approach and that didn't quite meet that criterion. I couldn't get loadfile to work for me - probably a shortcoming in my understanding of LUA.
Bill
You can also provide arguments in the Macro section of the document type.
As copied from the zScript/uncomment.lua macro:
dofile ("commentText.LUA")  -- #include file
That is Lua's include ;)
pwdiener
Post by pwdiener »
OK, I guess I got hung up on the "load and execute" description of dofile, since I didn't want to execute at the time I loaded. But again, perhaps my LUA understanding is a bit too shallow. I've written quite a few macros now, but I don't really feel like I understand the deeper aspects of the language.
In any event, that works perfectly for what I need. Thanks!
I still think a "How did I get here" macro function would be useful, but I don't have any immediate pressing need for it and it's not really very hard to live without.
Bill
