"Internal Debugger Configuration" grayed out
I'm just trying Zeus (3.97m) for the first time and want to try the debugger for Lua. Unfortunately I can't select a debugger in Debugger/Options as the pick list is greyed out.
Hi Glenn,
Can I first suggest you install the latest Zeus beta found here: http://www.zeusedit.com/z300/zeus-beta.zip
Things like the Zeus debugger support has been changing quite a bit recently so the latest beta version should give a better experience.
With the beta version from above there is now an easy way to select Debug/Release modes by using the toolbar.
You can also select Debug mode from in the workspace from the drop down list in the top left corner.
There is also a You Tube video that shows the Lua debugger in action found here: http://youtu.be/D5FTnVwc2SU
The Workspace has two sets of settings, Debug and Release and to change the debugger options you have to be in Debug mode.Unfortunately I can't select a debugger in Debugger/Options as the pick list is greyed out.
